Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Hay wagon rub rails
Leroy
09-13-2013 13:53:47
Do you see the pieces of wood that is still inside the rails? That is how thick your cross pieces are supposed to be minuse the piece of flooring that is still inside the box on top of the cross pieces. I can see that in your pictures. Just put the floor out only to the inside edge of the stake pocket holes. The little piece of angle iron at the stake pocket holes goes on the bottom and that is to keep the thin edge of that steel from wearing into the wood stakes for the wood sideboards (Some beds had steel stakes and steel sideboards instead of wood). Taper your cross pieces to fit inside of that steel rail from the point that the cross pieces set on top of the sill. And you want the floor to run lengthwise and not cross wise. That is exactly the same as the steel flat truck beds except for the fact that some had steel cross members in instead of wood. And it is a rub rail to keep you from busting up the ends of your cross pieces. Should be by looking easly seen how they go. And that was a very common way for the factory built beds to be made if they were a good quality. You should see what the bolts look like from the bit of cross pieces that are still in them and cut off. Exactly what I had told you earlier. Can't put pictures on or would show you a picture of one of the beds but I could snail mail you a picture.
gregweirauch
09-15-2013 19:28:45
 Re: Hay wagon rub rails in reply to Leroy, 09-13-2013 13:53:47
Thanks guys I think I got it. Gonna look for pic of old truck beds to be sure. Started working on another on paper will post when I get work drawings.
Super-H-Mike
09-14-2013 09:20:09
Ok, I see it now. I was confused also about how they would go, but Leroys explanation makes perfect sense. I have seen that on old truck beds now that you mention it.
