Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: SEED SPREADER OR GRAIN DRILL?
Texasmark1
09-06-2013 05:54:55
I made that decision this year for next year's planting. I thought about using my broadcast spreader but decided against it because I had better control with the drill, knew exactly where my seeds went, and could roll my packer behind it.
So.....I got some new springs for my drill from Mr. Nebraska Cowman and as soon as it cools off will install them. Next year I should have an even stand as all the seeds should be at the same depth, not some shallow and others too deep.
However if overseeding, it might be a different story but I don't so that makes the decision easy.
Mark
Phil H
09-06-2013 13:01:25
 Re: SEED SPREADER OR GRAIN DRILL? in reply to Texasmark1, 09-06-2013 05:54:55
I was wondering also if the birds could be a problem if I didn't get the seed covered by harrowing, and I see what you mean if all the seed is planted at the same depth, the stand should be a lot more even. thanks.....
coonie minnie
09-06-2013 18:35:01
 Re: SEED SPREADER OR GRAIN DRILL? in reply to Phil H, 09-06-2013 13:01:25
Birds can be a problem... the Van Brunt brothers made the first fluted feed cup to make an effective grain drill. Their farm was located near Wisconsin's Horicon Marsh, a large bird sanctuary and resting place for migrating birds.
They were sick of the thousands of birds eating the wheat seed they spread before they could get it harrowed in.
It was a sucess- and that's why they built a factory in Horicon. It's now owned by Deere and home of their lawn mower line and not drills any more.
Just a bit of useless ag trivia...
Phil H
09-07-2013 08:11:05
 Re: SEED SPREADER OR GRAIN DRILL? in reply to coonie minnie, 09-06-2013 18:35:01
Wow, a lot to be said for the grain drill, as I thought, because it would be timely to cover the seed if broadcasted. Maybe if I broadcast the seed or my wife could broadcast and I could harrow or use a packer, right away. I was also thinking of spreading some fertilizer, asap. like horse manuer, which has straw mixed in it, this might keep the birds from eating the seed. I guess that is why they pull a packer or drag chains behind the drill as they plant. Thanks for the info......
Texasmark1
09-07-2013 12:58:10
 Re: SEED SPREADER OR GRAIN DRILL? in reply to Phil H, 09-07-2013 08:11:05
After I drilled this year, Crows covered my hay patch, but seemingly didn't affect the seed count.
Mark
Phil H
09-07-2013 16:50:45
 Re: SEED SPREADER OR GRAIN DRILL? in reply to Texasmark1, 09-07-2013 12:58:10
Thanks, I guess that says it for the grain drill. Did you use anything to cover the seed? thanks.......
Texasmark1
09-08-2013 05:33:27
 Re: SEED SPREADER OR GRAIN DRILL? in reply to Phil H, 09-07-2013 16:50:45
The drill had the chains I call them; 3 or 4 2" to 3" circles looped in a chain with interconnecting links that follows the furrow.....covers the seed. Then I followed with a rolling packer that I had connected to the rear of the drill. I watched the crows and they did a lot of milling around the first couple of days. After that no birds.
Mark
Phil H
09-08-2013 12:42:24
 Re: SEED SPREADER OR GRAIN DRILL? in reply to Texasmark1, 09-08-2013 05:33:27
Thanks Mark, I have seen some pictures that showed the chains. Pulling the packer at the same time, makes sense, and the birds are a real factor......thanks.....
