vicon RP 1511 M baler string threading
Thanks for the reply, not sure if it is the type you suggest, I have a spool on side of baler, twine should go around then back into baler attached to a carriage that runs across to the other side as the spool turns. not sure how to attach twine to carriage and put twine into bale
that is the welger system wrap 2 or3 wraps on the little wheel smaller groove is fastest then in the hole over the roller trip it does the rest
if you hang the twine over the carrage mechanism so hay catches it that will start it moving and let it complete a cyle now it is threaded we run two vicons here very good machines
Thanks for trying to help me, I feel like an idiot that I don"t understand what you are trying to explain to me. where are you at,I will sell you this one cheap and buy a Vermeer baler. If I leave my email will you contact me so I can give you a phone number and talk me through this some evening. [email protected] Thanks
