TractorLinks.com
Re: van brunt EE settings
Leroy
08-22-2013 07:24:33
The book for a B or FB, FB being the fertilizer box version of the B, drill would get you close, the parts inside that feed would be designed to run at the same speeds-settings but the gearing for speed difference from the large steel wheel on yours to the small rubber tire on the others id made up with the drive chain off the wheel on the low wheel drill that the high wheel drill does not use. The only difference would be fluted feed or double run.
Tx Jim
08-22-2013 08:37:21
 Re: van brunt EE settings in reply to Leroy, 08-22-2013 07:24:33
Leroy
I think a FB isn't a fertilizer version of the B because FB had odd number of openers except for the 2 largest sizes while all B models had even number of openers
Leroy
08-22-2013 18:00:12
 Re: van brunt EE settings in reply to Tx Jim, 08-22-2013 08:37:21
Well the FB is a fertlizer drill and the b does not have the fertilizer box so could be some differences there but as long as they have the same type of feeding system the settings should be a good start for him.
Tx Jim
08-23-2013 04:28:25
 Re: van brunt EE settings in reply to Leroy, 08-22-2013 18:00:12
Here's a seed chart for a JD model B
M18023 Chart ADD 24.67 USD
