I have been looking for a JD 943 wagon hub for over a year now. Wanted on antique tractors, craigs list in Mn. Iowa ND SD but to no avail. Does anyone know where I may locate one. Hub nbr is S3519D it is for the later one after 1956 also found out the Jd nbr 30 potato digger uses the same hub manufactered 1956 to 1961. I need some leads. Thanks Gordy
Also check with Dean Bartels at Peosta, Iowa. He has a lot of older JD running gear and plow stuff. Just google his number. He also hangs out on here some too.
