Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: van brunt EE settings
D. N.
08-20-2013 18:22:15
Thanks for the reply Deltared, but neither one of those places have the manual and I also checked with www.manual.us too. On the setting adjustment next to oats is 50 and then another letter or number I can"t make out. I was wondering if it meant 50# and set the rate at the number 2 setting to get 100# per acre. Any way, still looking for a manual.
buickanddeere
08-23-2013 06:17:57
 Re: van brunt EE settings in reply to D. N., 08-20-2013 18:22:15
Deere sent me a manual for my old FB seed drill.1-800-522-7448.
Leroy
08-22-2013 07:24:33
The book for a B or FB, FB being the fertilizer box version of the B, drill would get you close, the parts inside that feed would be designed to run at the same speeds-settings but the gearing for speed difference from the large steel wheel on yours to the small rubber tire on the others id made up with the drive chain off the wheel on the low wheel drill that the high wheel drill does not use. The only difference would be fluted feed or double run.
Tx Jim
08-22-2013 08:37:21
 Re: van brunt EE settings in reply to Leroy, 08-22-2013 07:24:33
Leroy
I think a FB isn't a fertilizer version of the B because FB had odd number of openers except for the 2 largest sizes while all B models had even number of openers
Leroy
08-22-2013 18:00:12
 Re: van brunt EE settings in reply to Tx Jim, 08-22-2013 08:37:21
Well the FB is a fertlizer drill and the b does not have the fertilizer box so could be some differences there but as long as they have the same type of feeding system the settings should be a good start for him.
Tx Jim
08-23-2013 04:28:25
 Re: van brunt EE settings in reply to Leroy, 08-22-2013 18:00:12
Here's a seed chart for a JD model B
M18023 Chart ADD 24.67 USD
DeltaRed
08-21-2013 16:11:43
No book is odd...I recently ordered a new reprint book for my old JD 'B' drill.JD is supposed to have available(so they claim) all books for their older equipment.
Leroy
08-20-2013 18:52:57
I don't think they are rated for pounds but rated for quarts as 4 quarts per gallon and forget off top of my head how many quarts in a peck or quarts per bushel and they were figured at the legal test weight of oats at 32 pounds per bushel but good clean oats for seed will easily run 40 pounds per bushel so as well as the quart setting get that bushel test weight.
DeltaRed
08-21-2013 16:14:22
 Re: van brunt EE settings in reply to Leroy, 08-20-2013 18:52:57
I have a very old(horsedrawn)McCormick drill that is measured in pecks/quarts.
