Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD30 kicker hydraulic presure spikes???
wilder11354
08-20-2013 17:52:45
talked to local JD tech tonite, 38+ years experience. He says the regulator is set for a max pressure of 2200PSI +/- 200 PSI. Even if regulator fails to high siide thats max pressure its capable of making. He says the pumps are designed for a max pressure of about 3400PSI. And the system is designed to operate by spiking the pressure to unlatch pan latch and kick cylinder. So eaton is definitely blowing smoke sayig it had high pressure spikes of more than pump was designed to operate at. Beside JD tech says you would know by bales flying way past haywagon, and something else would give before the housing and bearings wore out.
