TractorLinks.com
Re: Tools Needed to Disconnect Drive Chain on Grain Drill
Retired Farmer
08-20-2013 12:07:58
If it is a newer model it should have roller chain. There is a master link with a thin U shaped keeper, or it could have two tiny cotter pins. If the chain is dirty you may have to look hard to find it. I just use a small sharp pointed awl or pick and a small or medium blade screw driver. Use either the pick or screwdriver to pry one side of the keeper out and up out of its groove. Then slip the other one under it to keep it up and pry it over so the other side comes loose. Then rotate the keeper and push it off the pin. Then push the master link off its side plate, may need a pair of pliers, and the chain will come off. Just watch your fingers.
