TractorLinks.com
Re: JD 630 Disc problem
peanut80
08-20-2013 09:58:09
The valve allows you to add down pressure to the wings so they will cut in hard ground. I am wondering if there is an internal leak in the cylinder allowing one side to not hold as much down pressure as the other and if there is a way to test this.
Mike Aylward
08-21-2013 06:26:50
 Re: JD 630 Disc problem in reply to peanut80, 08-20-2013 09:58:09
Yes, you can test this. The wing cylinders have two ports. Open up the return port and then fully open your adjusting valve to apply full down pressure. There should be no leakage out of a healthy cylinder. Mike
