#37 wheel disc axle seals
Tim Morland
New User
I need a part number for the grease seal on my IH 37 wheel disc. I've never seen the two piece type seal that is on there and neither NAPA or my local IH dealer have been any help.
Shaft is 1.562", bore OD is 2.327 and depth is about .700"
Let me know what y'all have used.
Thanks. Grub
Is the FIAT dealership WORTHLESS? According to the CIH on-line parts store, the CIH # for the later seal (1962 and up) is 472221R91.
This crosses to an SKF # 527521.
This is for a seal that the metal ring presses ONTO the spindle, and the rubber lips are on the OUTSIDE of the seal, and run against the ID of the hub (or a wear ring, if used).
Thanks for the reply. The seal I removed is 472223R91 and the rubber portion has three lips on it. I'll try to track down the SKF seal.
Grub
