TractorLinks.com
Re: Sickle mower clogging help
hd6gtom
08-19-2013 08:28:58
Gene we need more information to help. What tractor are you pulling this mower with? Your Mower bar will need to be tilted slightly upward in the front. Is the hookup at your drawbar the correct height from the ground? The outer end of the mower bar should be slightly ahead of the inside, there is always some drag on the bar, causing the outer end to be pulled back a little bit when mowing. Maybe the outer and inner shoes need to be moved to raise the mower bar up off the ground. Are you fighting gopher mounds or ant hills? Can you post a picture of the mower and the ground you are trying to mow?
