TractorLinks.com
Re: Sickle mower clogging help
maxwell99
08-18-2013 16:19:57
You can order a manual from JD at 1-800-522-7448.
Have your credit card handy. ~$16.00 total.
this info was on another yesterday tractor post.
if its still current it might be the best info I can give you.
buy the manual and set down and read it cover to cover, it should tell you how to set up the bar angle and knifes for best result.
does you tractor have an rpm meter, so you can tell your pto speed and ground speed?
as others have said, you need to know this info, so when you find your mower sweet operating spot. you can go back to that speed and rpm time and time again.
I have an old MF cycle mower and they can be Cantankerous at best in heavy hay.
just look around today and see how much heavy hay is being cut by cycle mowers verse the new type spinner mowers.
they will cut through most anything and the speed control is just as fast as the operator can stay on the tractor.
good luck with the old mower,
note to file: !!!!!!!!!! be so careful when you raise and lower the bar, remember the blade can slide up/down when you do this and you must, must, must have your fingers back out of the way!!!!!!!!!!!!
showcrop
08-18-2013 18:12:23
 Re: Sickle mower clogging help in reply to maxwell99, 08-18-2013 16:19:57
I haven't seen any hay being cut by a cycle mower, but last week I saw a lot of Amish cutting with their horse drawn gas powered sickle mowers. Other than the Amish I look around I don't see any one else cutting with a sickle bar. Not saying sickle bars are bad, just old and SLOOOOOOOOOOW school.
