Fjordman1995
The collar holding on the plunger bearing, do you remember if there were 1 or 2 set screws on that collar? I found 2 holes, one had a set screw the other doesn't seem to.
I can't see anything in that hole, but when I put a small awl into both holes the one I took the set screw out of seems about 1/16" to 1/8" deeper than the other hole.
The ring doesn't budge either, does it usually require using a gear puller?
I'll get it out of the field tomorrow, get some more light on the subject, too.
Thanks,
Warren
Thanks,
Warren
