Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Cyclo 800 end transport
James22
08-09-2013 22:26:06
My suggestion would be to find/locate a used or new vertical section of a gooseneck which contains the ball latching system. Attach the entire vertical neck to the box beam that extends from the planter frame and normally attaches to a 3pt mounted bar. Could be welded directly but possible to weld brackets on each side with the necessary holes to use a couple of U bolts around the planter's extended box beam. Should be able to mount a ball on your rear hitch, connect and tow. Alternative might be to completely shorten the vertical neck so that you only have the ball latch mechanism and use the normal gooseneck ball already mounted in the truck bed.
