Bushog 266 repair
Bonnan
Just can't bring myself to scrap it. This very old mower just dropped the pan/blades; the nut came off and apparently was loose for a while as the keyway on the shaft is badly peened opened. Can one machine a new slot 180 degrees around the shaft? Does anyone have a better repair idea?
Have had a new key way machined 180 degrees on many shafts over the years. If the taper and threads are OK it will work fine to have a new key way machine in it.
