IN NEED OF John Deere 555 rear wheel
Garri
I am in need of the rear wheel for my John Deere 555
drag plow. Does anyone have one for sale or know
where I can get one? I would greatly appreciate any
help. I need it rather quick. Does anyone know the
bolt hole spacing? The best I could tell it is 4 on
4 1/2. Thanks.
I'm sure you would like a rubber rim but the large metal wheel on JD trailer and mounted plows will fit right on there and get you going.
I'm not 100% sure, but a wheel off of a 55 Plow will also fit. Just opens more opportunities for finding parts. My f-I-l had a 55 plow and I robbed parts off of that for my 555 plow. Hope this helps you.
The first thing we need to know is if it has the small 12" diameter furrow wheel on or if it has the larger car tire size that could be a 14 or 15" tire? the latter any 4 bolt implement rim will work, the smaller might be harder to find but a boat trailer wheel might work.
What I need is the small 12x4 rim that used the rubber tire. A blank rim won't do me any good due to the fact I don't have a center to weld in. The mounting flange and everything else is there, just not the rim - wheel.
That same wheel fits the mounted plows as well. Don't have any idea where you are from but if within driving distance of West Central Ohio I could give you the name of a parts yard that I think would have it.
