tractorsam
I have an older tedder/rake combination and I ordered some teeth for it based only on the best of the old ones, the teeth that came will work fine with one exception. The way the teeth are made there are two fingers, the material starts, goes up to a spring coil, makes a small U-shape that sticks up above the coils, comes down into the second coil, and then goes down to finish. The U-shape that sticks up goes into a socket on the rake and then a bolt goes through to clamp it. The new teeth I've got are just a little too wide in the U-shape and don't fit properly in the sockets. Can I heat the teeth and close the 'U' a bit or will that destroy the metal and make them fall apart? Thanks, Sam
