TractorLinks.com
Re: 336 john deere baler with 30 thrower problems
farmboy4450
07-15-2013 11:52:50
if the slip clutch was bad would that affect the whole baler not just the thrower? the whole baler itself works just fine. no troubles
MFan
07-15-2013 12:11:07
 Re: 336 john deere baler with 30 thrower problems in reply to farmboy4450, 07-15-2013 11:52:50
I"m assuming that it throws the best when the hydraulic oil in the thrower is cold? If so, once the oil is warm and thinner, what seals could it be leaking past to reduce thrower power?
farmboy4450
07-15-2013 12:20:28
 Re: 336 john deere baler with 30 thrower problems in reply to MFan, 07-15-2013 12:11:07
yes. it throws the best cold. obivously not too cold but cold from sitting. pretty pathetic when it cant throw straw bales to the back of the wagon
Tim(nj)
07-15-2013 12:41:16
 Re: 336 john deere baler with 30 thrower problems in reply to farmboy4450, 07-15-2013 12:20:28
the pump could be worn out. I had one that would work with cold oil but as soon as you made 20-35 throws it would lose distance. That's what my problem was, yours may be different.
farmboy4450
07-15-2013 15:15:49
 Re: 336 john deere baler with 30 thrower problems in reply to Tim(nj), 07-15-2013 12:41:16
where would you check the pump pressure at? i have guages for hydraulic testing.
