TractorLinks.com
Re: This baler is driving me crazy!
nh014
07-10-2013 20:00:27
Continual loss of the # 2 twine when all knotter, twine finger, and hay dog adjustments have been checked is a good indication that hay movement in the bale chamber is deflecting the twine as it is being delivered to the knotter.
To resolve the concern add restrictors to the sides of the bale chamber to keep the hay from springing back. It was also a common fix on 60"s and 70"s NH balers to add extensions to the face of the plunger, again to move the hay further rearward during the tying cycle.
RayP(MI)
07-10-2013 20:19:14
 Re: This baler is driving me crazy! in reply to nh014, 07-10-2013 20:00:27
Have 3 restrictors on each side. Have thought about adding extensions to plunger. Baled last field with bale tension screws fairly loose, hay was extremely dry, and bales were loose.... (Actually tightened them several times, no avail.) Problem still there. Baled up a bunch of broken bales off wagons, barn today. Bales were very solid and very heavy. Doono what"s going on!
nh014
07-11-2013 16:48:26
 Re: This baler is driving me crazy! in reply to RayP(MI), 07-10-2013 20:19:14
The fact that you can not obtain a good solid bale confirms my suspicion about hay movement.
Lets go back to windrow formation. The more uniform the windrow, and the more uniform the amount of crop flow into the baler, the more uniform the bale shape, bale length, and tying will be. Where crop fails to fill the top of the bale, increase the size of the windrow by double raking or combining windrows. Operate the baler at 540 rpm and adjust ground speed to maintain a consistent and even flow of crop into the pickup. Ground speed and crop flow that produces 14 to 16 plunger strokes (bale slices) per 36 inch bale, or 15 to 17 slices per 40 to 42 inch bale will produce the most uniform bales. As the windrow size varies, adjust the ground speed to obtain the proper number of slices per bale. In extremely light / springy hay consider bale chamber liners in addition to the hay restrictors.
