Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: two row pull type corn picker
Deere Scotty
07-09-2013 22:24:21
Its not easy; but can be done. If You buy a 325, It will be already be set for 32" rows. They are made to work 28" - 36". The 324 is set at 40"'s. 36" - 44" rows. That means You will be 8"'s off center. Double whats intended. Worse yet; the outside of a 324 will sit closer to the passing row outside. It will be much harder to keep from knocking over the next pass row, sideways; which in turn weakens the stalk which will have to be pushed back over the other direction when You come back around for it! If its brittle enough it may simply fall over flat.
