Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Boom pole pipe dimension
old
07-08-2013 19:30:25
I built one years ago using a 2 inch pipe and then since I had it laying around I welded a U bar to the bottom to make it stronger. I have bent it a little bit but I use it to lift to much at times. If you weld a piece of angle iron to the top or bottom to make it stronger you will probably be just fine for say under 800lbs which if pretty much max if your going to use your Ford N series. My boom pole is set up so I can use it on a 3 point or on my loader bucket for extra lift
