TractorLinks.com
Re: Round baler 545 problem
Kati
07-08-2013 00:10:30
John Deere 545
Tx Jim
07-08-2013 03:53:31
 Re: Round baler 545 problem in reply to Kati, 07-08-2013 00:10:30
Check to see if the spool on the hyd valve(parts key #9) is shifting to the "twine apply" mode when tail gate is closed, I've seen the spool get dirty causing it not to shift plus hay/chaff build up not allowing it to shift. Are ALL 5 springs intact and attached correctly??????
This post was edited by Tx Jim at 03:56:44 07/08/13.
Kati
07-08-2013 09:21:58
 Re: Round baler 545 problem in reply to Tx Jim, 07-08-2013 03:53:31
Aitah! (Thanks!)
I forget mention before. Baler make ball and not started stringing. We want smaller ball, husband regualted machine, but ball is same. Then he make started stringing manually. I named this action machine not understand, when ball is ready
Tx Jim
07-08-2013 09:27:26
 Re: Round baler 545 problem in reply to Kati, 07-08-2013 09:21:58
Sounds like typical symptoms for twine valve mechanism that doesn't reset when tail gate is closed. Refer to my first post.
Kati
07-08-2013 09:35:41
 Re: Round baler 545 problem in reply to Tx Jim, 07-08-2013 09:27:26
Ok, now it s clear. We are talk about same thing. Thanks :)
Tx Jim
07-08-2013 11:19:55
 Re: Round baler 545 problem in reply to Kati, 07-08-2013 09:35:41
Kati
May i ask what country you & your husband live in?
Jim
Kati
07-08-2013 11:55:49
 Re: Round baler 545 problem in reply to Tx Jim, 07-08-2013 11:19:55
Estonia :D
Kati
07-08-2013 22:55:37
 Re: Round baler 545 problem in reply to Kati, 07-08-2013 11:55:49
Problem?
