I have a 1465 that the reel is slipping alot and
plugging, mostly due to cutting 1st way late.
Glad crop is great, not so glad to have to fight
with the Haybine. I found that there is a belt
tension for the reel, which I can adjust, the book
is so helpful, it says if it's slipping and not
within spec for reel pressure to turn backwards
should be approximately 200 pounds to adjust the
spring, however, it does not even give a clue as
to which direction to move the spring, up the bar
or down??? Anyone know? Thanks! Leo
