TractorLinks.com
Re: Kuhn GMD700 Disc Mower
rwskinner
06-26-2013 20:14:18
Kuhn & JD only call for 2 of the high lift skid shoes. They also state that you should not roll the bar up past level or horizontal of severe wear will occur. Pretty weird.
Richard
RodInNS
06-27-2013 06:57:46
 Re: Kuhn GMD700 Disc Mower in reply to rwskinner, 06-26-2013 20:14:18
If that's all they call for, install them as recommended...
As far as rolling the bar rearwards... what will happen is it wears the nuts off the shoe retainer bolts... and can wear a hole in the outer rear end of the pan. That's if it's on a severe rearward tilt. I sometimes roll mine back if I'm in a rough or rocky field as it will skip over a lot more problems that way.
Rod
rwskinner
06-27-2013 11:48:00
 Re: Kuhn GMD700 Disc Mower in reply to RodInNS, 06-27-2013 06:57:46
That is what I'm trying to say, there are no recommendations. Local Dealer can't say where to put them because they are a new dealership and hadn't installed any before and there is no documentation.
Also, if I put one on each end, I had to remove the shoe each time to check the cutter bar oil.
I guess I will stick them on each end. Poor setup if you ask me.
Richard
