Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD 346 random bale length
Tx Jim
06-23-2013 07:39:13
Too much air pressure in LH tire can affect bale length if in a rough field. Measuring wheel components were altered at SN 285,000. The stop(parts key #23) was made heavier and spring(parts key #4) was added. I have seen extra weight added in severely rough fields.
vernon in ks
06-25-2013 09:31:59
 Re: JD 346 random bale length in reply to Tx Jim, 06-23-2013 07:39:13
Make sure the nut #28 in jims pic is TIGHT. If not you will get all lenghts.
JohnS1970
06-24-2013 04:41:51
A number of years ago our 336 would make varying length bales and the problem that time was worn bushings Key#6.
Tx Jim
06-24-2013 04:55:00
 Re: JD 346 random bale length in reply to JohnS1970, 06-24-2013 04:41:51
Actually replacing the worn bushings(#6) while leaving the brackets(#5) where they were will cause more pressure to be applied between roller(#21) & sector(#26) causing less slippage between roller/sector as measuring wheel turns. This pressure can also be adjusted to a degree by moving brackets rearward.
Copyright © 1997-2015 Yesterday's Tractor Co.
