TractorLinks.com
Re: remote Hydraulic only works when pressing both control
JD Seller
06-22-2013 06:58:59
Are you sure you have the hoses hooked correctly??? Some of the new tractors have the couplers up and down not side by side. So if you have four couplers they are paired up and down not right and left. The reason I am asking your issues are classic hose hooked to two different SCV valves.
Also check to see if you have a bad hose end. I have had them go bad and cause all kinds of odd things.
ranco3030
06-24-2013 09:36:25
 Re: remote Hydraulic only works when pressing both control in reply to JD Seller, 06-22-2013 06:58:59
I know it seems that would be the problem but I have had the tractor for 3 years I have been bailing hay with it hooking it up the same way
BrIONwoshMunky
06-26-2013 16:52:06
 Re: remote Hydraulic only works when pressing both control in reply to ranco3030, 06-24-2013 09:36:25
Have you tried hooking it up to the other remote? If, for some unforeseeable reason, the fluid doesn't bypass the first remote until it's operated, it may work on the first in the system, but not the second.
I wouldn't put much hope there, but it could rule out a single remote being the problem instead of the whole system.
