Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Twine Tension In 430 IH Baler
JD Seller
06-22-2013 06:51:45
The twine being lose right after the knotter is common. Plus you can't really tell anything with wet hay. Truthfully if it tied wet hay then it should fly in dry hay. Most balers will not tie wet hay.
Tim Stolar
06-24-2013 06:33:05
 Re: Twine Tension In 430 IH Baler in reply to JD Seller, 06-22-2013 06:51:45
I tried the baler out this weekend to attempt to salvage the hay that had gotten wet. All in all, she worked great. There was only one bale that broke, and that was because of bad twine more than anything as the knot was perfectly tied but the twine had a black mark where the break happened.
I have been experimenting with it to keep the tension better on it by giving a lot of down pressure on the bale and then decreasing the knotting length so that once it pops out, it fills that void that the twine left so that it is the proper size and is nice and tight.
I have to say though, that for $150.00 she works really damn good!
merlynr
06-22-2013 09:36:40
My old baler hates wet hay worse than I do.
