Yesterday's Tractor Co.
Shop Now View Cart
Re: Question on surface wrap(net) on a JD 467 baler?
JD Seller
06-22-2013 06:30:59
TX Jim: The bar/switch that tells you your out of mesh should tell you that the baler did not get mesh on it. This is only true if the mesh actually did not run. This switch is the little micro switch on the right side of the mesh wrap rolls. If you look a small "C" shaped channel runs across the baler. It pivots on two pins that are on one side of the channel. When the mesh wrap is cut it rubs across this channel. It swings because of this pressure. This motion trips the micro switch. If it does not swing the baler monitor should show no mesh alarm. I have had issues with hay/chaff getting behind this channel/bar and not working correctly. You just need to blow out the back side of it. Maybe lube the pivots.
The other thing that can be happening is that the mesh is getting wrapped around the top roll on the gate. I have trouble with this sometimes after the baler has set for a period of time. What happens is that the mesh wrap goes around the bale until it gets to the top where the belts change at the top two rollers. The mesh has to go across the gap from one roller to the next. Instead of going around the bale like it should it wraps the rear roller. If the wrap has a real ragged cut edge it will make this worse. Then the wrap will kind of pull off with the next bale but usually there is wrap around the ends/bearings. Clean the brush and check to see that the knife is sharp either can cause a too ragged cut edge.
If I get a non wrapped bale I stop and check right then. If it is wrapped on that top roll you can wipe out the bearings real fast. The wrap gets around them so tight I have had to take out the roll to get it off.
I also have two mirrors that look back at the baler. I can usually see with one of them if the bale has wrap on it. You can usually see the mesh between the belts or if you are looking in the pickup you can see that the hay is not dropping when it passes the throat opening.
Check the switch and check the rolls. If they are OK you more than likely have an operator issue.
The switch is number 20 in the picture.
Tx Jim
06-22-2013 06:59:04
 Re: Question on surface wrap(net) on a JD 467 baler? in reply to JD Seller, 06-22-2013 06:30:59
JD Seller
Thanks for the reply. I have already checked and ruled out what you outlined. The thing that baffles me is there will be some netwrap lying under the exploded bale. That's why I was thinking operator error or monitor malfunction. My operator states "not me but machine problem. Yea right as this isn't my first rodeo.
Thanks again,Jim
06-22-2013 08:05:05
 Re: Question on surface wrap(net) on a JD 467 baler? in reply to Tx Jim, 06-22-2013 06:59:04
My JD 467 does the same thing, I'm thinking I'm doing something wrong. I noticed when monitor says it's wrapping, it don't last long enough to make the right amount of wraps, usually one wrap and my monitor is set for 2 1/2 wraps . So, I just hit the wrap button and it puts the right amount. Takes a good bit longing baling, but they're all wrapped.
Tx Jim
06-22-2013 09:01:14
 Re: Question on surface wrap(net) on a JD 467 baler? in reply to WAYNE-N-TX, 06-22-2013 08:05:05
That makes me feel a little better. Aggravating as it is at least that makes me not want to fire my hay baler operator.
Tx Jim
06-22-2013 09:05:55
 Re: Question on surface wrap(net) on a JD 467 baler? in reply to Tx Jim, 06-22-2013 09:01:14
JD Seller
If some netwrap is on bale or under exploded bale but not wrapped on any rollers won't that rule out the switch you referred to???
JD Seller
06-22-2013 21:49:10
 Re: Question on surface wrap(net) on a JD 467 baler? in reply to Tx Jim, 06-22-2013 09:05:55
NO!! If that switch is not tripped the monitor thinks it is still warping the prior bale. There is series of things that have to happen in the correct order for the monitor to reset for the next bale. One of the last things is for this micro switch to be tripped. This tells the monitor that the prior bale is done and fully wrapped.
You saying you have a little wrap under the bale is telling me the bales is not completing the prior bale correctly and still thinks it is finishing it when the new bale starts to wrap.
It is a quark in the monitor that will allow this to happen. The half that is monitoring size is happy because it said to wrap the bale. The half that handles the actual wrap possess is not happy because it thinks it is not done with the prior bale.
So if that switch is not tripping every time it will make the monitor act real odd. As for the brush question. I don't think I said anything about a brush maybe being an issue. There is the brush that keeps the roll clean.
Another thing to think about. If the operator is jumping the gun and dumping the bale before the mesh wrap cycle is complete it will cause the monitor not to reset. I am meaning just a few seconds will do this. The bale is all done but tripping the micro switch. So the monitor may finish the prior wrap cycle rather than reset and start a new one. I have done this when really pushing bales of corn stalks through. You kind of get into a rhythm and hit the SCV without really thinking about it. You kind of jump the gun on the monitor finishing the wrap cycle. Then the next bale is not wrapped fully. It may only have a few feet of mesh under it. The monitor just finished the little bit it thinks it needed on the prior bale.
Tx Jim
06-22-2013 12:52:57
JD Seller
I blew off the brush but I fail to see the correlation between the brush and netwrap not getting wrapped around the bale. It appears to me than brush is intended to keep steel feed roller in netwrap attachment clean.
M w J
06-23-2013 11:56:32
 Re: Question on surface wrap(net) on a JD 467 baler? in reply to Tx Jim, 06-22-2013 12:52:57
On our 567 if we don't get 2 complete wraps on the bale and the kickbar hits the spot with 1 wrap it will sometimes explode the bale and then the bale will land on the piled up mesh wrap not all of it will be under the bale but most of it is.
Tx Jim
06-23-2013 17:31:32
 Re: Question on surface wrap(net) on a JD 467 baler? in reply to M w J, 06-23-2013 11:56:32
I always put 2 wraps on grass hay
