more JD-8300 drill ???
cdv
ist thing order all 3 manuals today form JD,, todays ?? is how do you ajust seed flow on this thing there are no handles on the front or back side of it,,other then the ones on the seed boxs and thanks to Ron found my ser#023180 thanks cdv
If the has no levers to change the seed openings then you must have a double-run drill which requires changing gear settings to set seed application amounts. DR type is more difficult to set but is supposed to be more accurate than fluted feed type. Does it have shafts that resemble these in the parts photo??
