remote Hydraulic only works when pressing both control
Ranco3030
New User
I have a 2005 Case JX95 /cab that has a hydraulic problem. it started only lifting the door on my JD bailer by would not let it down. all fluids was fine. I service the tractor installed all new filters. still had the problem. I was playing with it and found out if I press both remote levers at the same time the door will open and close just fine. anyone have any ideal what it could be?
If JX series has the electric over hydraulic controls like the larger MX series it could be a computer problem.
I just went through similar issues on my 2002 MX and they had to update some computer issues.
Works fine now but needs to be hooked to a computer to find the problem. Dealers only.
Gary
Are you sure you have the hoses hooked correctly??? Some of the new tractors have the couplers up and down not side by side. So if you have four couplers they are paired up and down not right and left. The reason I am asking your issues are classic hose hooked to two different SCV valves.
Also check to see if you have a bad hose end. I have had them go bad and cause all kinds of odd things.
I know it seems that would be the problem but I have had the tractor for 3 years I have been bailing hay with it hooking it up the same way
Have you tried hooking it up to the other remote? If, for some unforeseeable reason, the fluid doesn't bypass the first remote until it's operated, it may work on the first in the system, but not the second.
I wouldn't put much hope there, but it could rule out a single remote being the problem instead of the whole system.
