Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: One side of rotary cutter does not cut well
Harvey2
06-21-2013 13:04:37
I'm glad you didn't call your John Deere rotary cutter a bush-hog
A lot of people think every rotary cutter is a bush-hog.
T in NE
06-23-2013 11:45:43
 Re: One side of rotary cutter does not cut well in reply to Harvey2, 06-21-2013 13:04:37
That's because they defined the segment, like Vice-grip with locking pliers, Bobcat with skid-steers, Cat with crawlers, IHC (payloader) with front-end-loaders, and Channellock with tongue-and-groove-joint pliers.
Tx Jim
06-21-2013 13:23:26
Harvey2 said: (quoted from post at 16:04:37 06/21/13) I'm glad you didn't call your John Deere rotary cutter a bush-hog
Back in the 50's-60's JD called them Gyramor. This model lists CW & CCW blades
727 and 737 Rotary Cutter, Gyramor - 01Jun11
This post was edited by Tx Jim at 13:25:27 06/21/13.
CT8N
06-21-2013 19:13:05
 Re: One side of rotary cutter does not cut well in reply to Tx Jim, 06-21-2013 13:23:26
Thanks,yes I remember now, it is a gyramor 737. I put a decal on it several years ago, and it wore off. John Deere has a zero turn mower with the same model number which does not help looking up things.One blade does turn cw and the other ccw. It works fine when cutting low, but one side drags over fescue when cutting high.
Tx Jim
06-22-2013 04:17:18
 Re: One side of rotary cutter does not cut well in reply to CT8N, 06-21-2013 19:13:05
Does your cutter have flat or suction blades?
CT8N
06-22-2013 05:25:41
 Re: One side of rotary cutter does not cut well in reply to Tx Jim, 06-22-2013 04:17:18
They are suction type.
