TractorLinks.com
Re: JD 350 sickle bar mower question(s)
Lpmm
06-20-2013 17:22:48
Great little mowers. Just check the wobble head for excessive play, sickle should move with the smallest movement on belt side. Make sure it turns smoothly. Just have to set the sway blocks or chains to hold it center, there is a chain that goes to the drawbar it lifts the bar end just adjust to correct length. The owners manual is available from JD.
RayP(MI)
06-20-2013 18:48:37
 Re: JD 350 sickle bar mower question(s) in reply to Lpmm, 06-20-2013 17:22:48
Exactly what I was going to say. My tractor has a stabilizer bar on one ofthe 3pt hitch arms. Price seems a little steep, but that's just me. I've fought about every battle there is with a 350. There should be little play in the pin between the wobble drive and the knife bar header. Proper hold downs and plates behind the knife bar is essential and must be properly adjusted. Rock guards being of different brands probably not a problem, just indicates they have been replaced throughout the life of the mower. I end up replacing a couple every few acres due to breakage. (Lots of mole hills with rocks in them.)
