Farmhand bale accumulator
Anonymous-0
Anybody run an accumulator off of tractor hydraulics? I tried, but keep blowing off the return hose when the push over returns.
You need to have a dump port straight back to tractor hydraulic reservoir as big as the dump line which I believe is 3/4 inch. Sounds like you have a restriction on dump causing to much pressure in dump line and then blowing the hose off. Hope this helps.
