Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Dearborn 14-15 Mower Bracket
jcmorgan31
06-07-2013 10:15:40
The bracket on the right side doesn't have the ball. It is just a regular bracket with a hole in it large enough to accept the large pin on the break away bar. I think that is another reason the mower rubs the right tire so bad because without the ball there is no give to the left.
I can tell it isn't good for the tractor the way it is and it makes it very difficult to operate. Every time you lift the implement it shifts into the right rear tire which makes it almost impossible to back up with the mower off the ground. I really didn't have an option this time, but I won't mow with it this way again now that I know.
And yes, it was a real job just to get it on the tractor.
Mel-N-WV
06-09-2013 05:08:54
 Re: Dearborn 14-15 Mower Bracket in reply to jcmorgan31, 06-07-2013 10:15:40
When I got my 14-15 it came without the RH bracket(or any of the necessary brackets). I got the dimension (which I don't remember right now) from someone on the net. I cut off a section of a broken lower lift arm, cut a chunk out of the homade under axle bracket and welded the ball section to it. It's not too pretty but it works.
Mel
Jason S.
06-07-2013 12:52:55
I would watch eBay and on here also for a set of the stabilizer brackets. They are the same brackets as the Ford N series tractor. The right hand one needs to have the ball in it. Here are some pics of the right hand bracket and the lift arms and top link bracket. A lot of times on eBay if you search for a Ford top link rocker some of the used ones on there will still have the top link bracket attached for those mowers because the sellers do not know what it is.
KathrynK
06-28-2013 23:31:59
 Re: Dearborn 14-15 Mower Bracket in reply to Jason S., 06-07-2013 12:52:55
I'm looking for one of those top link brackets too. We've been scouring eBay and online sources trying to find one with no success. We already have most of the rest of the attach points hardware, such as the L and R under-axle brackets. But that top bracket has been elusive. We're to the point of thinking about making one. Can someone tell us what those set screws are for? The overall structure looks straightforward enough that our welding buddy could fab one for us, except for those set screws.
jcmorgan31
08-22-2013 18:34:46
 Re: Dearborn 14-15 Mower Bracket in reply to KathrynK, 06-28-2013 23:31:59
Scored a top link bracket on Ebay today!
If anyone is still looking for one, I may know where another one is. Believe it or not, I was looking at Ford tractors on Craigslist and saw the bracket on the back of a Ford 600. I texted the guy and he is going to look at it tomorrow and let me know if he will sell it separate. Then out of the blue, I run into another on Ebay. 2 in 2 days and I"ve been looking for 4 months....
