TractorLinks.com
Re: Dearborn 14-15 Mower Bracket
Leroy
06-07-2013 05:37:59
To mount that bracket you have to loosen the fender bolts so just lift the fender off and use the fender as a guide for making them as the fender bolts are what holds it on so that measurement is the easy one. The next one is the trickey one and that is getting the short stabilizer pin alligned exasctly with the lower lift arm pin as that has to be exact or will make things bind. And the pin goes on the inside of the bracket. You could just go to TSC or the like and buy one bracket (they are universal fit for left or right sides) and a large angle iron for less money than having one made as unless your shop is different than most it would be hard for you to drill the 11/16th inch holes needed for mounting as well as for the pin.
