TractorLinks.com
Re: Front Adjustment on a New Holland Rake
Tx Jim
06-06-2013 05:52:23
The adjustment you referred to changes the angle that the teeth touch the hay. The higher the adjustment on the rake the more lift the teeth give to the hay. This adjustment has some affect on roping the windrow.
david1
06-06-2013 16:54:44
 Re: Front Adjustment on a New Holland Rake in reply to Tx Jim, 06-06-2013 05:52:23
Thanks, I am going to raise mine up. Not sure why anyone would want it lower.
onefarmer
06-06-2013 17:28:38
 Re: Front Adjustment on a New Holland Rake in reply to david1, 06-06-2013 16:54:44
Might want a tighter windrow if you was going to run it thru a chopper.
Josh in WNY
06-06-2013 10:11:13
Jim is correct. The higher the front is lifted, the more the hay gets lifted up and it will leave a windrow that is more fluffed up. If you want a more packed windrow, then move the front setting lower.
T in NE
06-09-2013 10:32:11
 Re: Front Adjustment on a New Holland Rake in reply to Josh in WNY, 06-06-2013 10:11:13
The fluffier winrow helps drying, is the theory behind the adjustment.
