New Holland 472 haybine
bynum
New User
I need help. I have an older NH 472 hay-bine with the slip clutch on the gear box. I thought I had everything ready to cut hay in the morning, new sickle blades and all. I was hooking up late this evening and ran it a minute an noticed the big pulley that the drive belt is on was wobbling. I rotated the rollers and saw where a set screw on this pulley ( at the slip-clutch) was missing. I need to know if the set screw rests in a hole in the shaft or is just a set screw that tightens down on the shaft. I really need to start cutting tomorrow so any help is appreciated. Sorry for long post but I need help.
No experience with NH, but most often they are either right on the shaft, or on a key. If you want, stick a drill down the hole and put in a drill spot to seat the screw in. Use a 5/16 drill for a 3/8 set screw, or a 1/4 drill for a 5/16 set screw.
Donovan from Wisconsin
