TractorLinks.com
Re: Flail Mower repair...
evilboweivel
05-23-2013 08:16:14
find a welder that you trust and let him do it his way
he is the one who will be staqnding behi9nd his work
good luck
Ron
pcastleberg
05-23-2013 08:38:50
 Re: Flail Mower repair... in reply to evilboweivel, 05-23-2013 08:16:14
I found a welder I know and trust, I am having the plates fabricated to weld in so that they will be precise (the bearing housing goes through the center hole and it should be a very precise fit) and we don't have to try to hard to get the holes right etc, it will all be setup and we'll just have to put it on and weld it up.
I also am concerned about the inside clearance from the mower blades that are on the outermost edge of the cutter shaft, I don't want them contacting the new plate, so I am thinking of having the plate made as a circle with the diameter just smaller than the outside arc of the blades or knocking the corners off to ensure they don't interfere with the operation of the mower.
