akburdette
New User
Was wondering if any one knows why when i am bush hogging my pto. keeps disinguaging on its own? my tractor is 1944 2n. am using 5ft. bush hog brand bush hog. some one at work said that i need to greese the pto male and female shaft as to allow for more free movement?
There can be several reasons for this.
You should have a good grease and maitenence program for your equipment, aside from this issue. Hopefully you are doing so. If lack of grease is causing this problem, you are going to have many more issues down the road.
There are parts on the tractor - it is 60 or more years old - that wear down over time and use. Shafts wobble a bit, the hand lever wobbles a bit, as holes wear bigger. Some of the parts connected to the pto lever can just be worn down, and no longer catch and hold where they should, allowing things to slip apart.
It sounds like you are not so very mechanically inclined, so it may be difficult to get a quick and easy explanation? It is a process to go through and check stuff, eliminate some of the reasons, and focus on the more likely worn, loose, or stiff parts that cause this.
I know I'm not answering your question exactly, but hopefully this starts you down the road, and can work through it to find the real cause of the problem.
Paul
Could be a number of things causing that. You will get more answers down in the 9N/2N/8N forum
Dent ball/spring maybe weak or the slide coupler maybe going bad or the bearing at the end is going bad etc etc
