6' offset disc
Do you guys think a Kubota 3240 diesel hydrostat tractor will pull a 6' double gang offset 14 or 16" disc in sandy loam soil OK? Tractor has weighted tires.
The horse farm where I work wants to till a field and I have the above disc. If it wouldn't work tho' it wouldn't be worth the trip to get it to the farm since it's about twenty miles...
my uncle has a 4240 Kubota 4x4 hydro drive, it works it pretty hard to pull my 3pt 71/2' tandeum on the hills, a offset should pull much harder but you may get by on flat ground if it is a heavy offset you may be biting of more than she wants cnt
It'll pull it just fine as long as you don't set the blades on the ground. When you decide to set it on the ground, make sure you've got 60+ PTO HP tractor in front of it. Preferably a gear drive. 80 hp would be even better. Offsets like to run at 5 to 5-1/2 mph and that takes power.
Rod
If it what they call an "offset disk" around here, that is 2 gangs, with front and rear turned at opposing angles, then it takes a minimum of 10 HP (rated at PTO) per foot of offset width. Therefore in your case 60 PTO HP rated tractor. Tom
Offset disks are heavy and pull harder. A typical regular disk it probably would pull.
You say offset, but you list fairly small blade size, so that is kinda in a questionable spot there....
Paul
26's become 16's when you run them over enough rock... I dread the though but I'm going to have to re-blade the front of my offset next year. That's a 9' Taylor-Pittsburgh and I don't imagine it will be cheap.
I've seen some poor little 6' Bush-Hog offset's that look exactly as the OP described tho...
Rod
LOL, I think that is what happened to this one, the farmers that used it "back in the day" were not exactly careful types. (three or four well chipped blades)I didn't exactly measure it or anything, that was my eyeball measurement of the blades tho' I do have a couple decades of carpenter experience so I know I am pretty close on the size they are now...they
could actually be twentyish . :)
Was afraid tractor wouldn't have enough umph, now I know for sure. Thanks to all for the input.
