TractorLinks.com
Re: 400 cyclo fertilizer chart
Caseyc
05-16-2013 19:33:32
If you have low rate augers the max you can apply is 130lbs with a #17 driver and a #15 driven. If you have high rate augers then you need a #8 driver and a #15 driven for 150lbs.
Casey in SD
Caseyc
05-16-2013 19:55:43
 Re: 400 cyclo fertilizer chart in reply to Caseyc, 05-16-2013 19:33:32
I should add there is a extra high rate auger also in which the minimum you can apply is 230lbs. If your not sure what auger you have then follow this procedure to find out.
Remove one delivery tube and tie a bag to the spout under the hopper. Engage the fertilizer drive and drive the planter forward for a distance of roughly 136 feet. Weigh the amount of fertilizer caught in the bag and multiply by 100. The result will be the total pounds per acre.
Casey in SD
