Implements for AC model WC tractor?
BrYng
New User
I am in search of photos or descriptive information and specifications for implements that attach to an Allis Chalmers WC.
Do model WD implements fit?
Hope to find out.
Im sure implements will fit either the styled or unstyled WC. That being said, Im 1/2 sure they will fit a WD.
The ones im most familiar with them fitting are the belly sickle mower, the cultivators, and planter. I KNOW there were more implements that fit, but I don't know what they were.
Cultivators do not fit both. Some mowers fit. Corn picker fits, with correct mounting brackets. WC does not have hyd, so that eliminates a bunch.
As JMS/MN says and also if it has the mechanical lift then that adds to what might work on it. Things like a 2 bottom trip rope plow or a pull type disk or most any pull type equipment sized right will work
Yup- the WC mechanical lift has a little lever that you can set for "cult" or "list". I"ve never seen a lister on a WC, so I don"t know what the lever does.
Picker is about the only thing. I know you could put a WC cult on a WD, they had a kit for that. Somewhere in my literature collection I have an implement catalog for the WC. They did have a lister as well as pull type plows, mowers, even a planter if memory serves.
AaronSEIA
I have part of a WC that has that mechanical lift on it but since I do not have a WC it just sits out there on that parts WC I have. One of these days I figure some one will want it so it just sits there
Picker only???????:That is so wrong. IDK about a kit for cult- would like to see that. But other machines?....yes!
