Fjordman1995
Working on a New Holland 271 hayliner. So far there are 2 things wrong. First, the major one, the tine bar sprocket was missing the needle bearings! Previous user wrapped wire around stub axel and packed it with grease and fiber washers. Not sure if that was the cause, but second problem was the needles were snapped off. I have replaced them and when I look up towards the bale chamber the right (from the back) needle is about 1/2 inch higher than the left. I would guess the right one probably hit the plunger and bent it higher.
Anyone know if this is needs to be adjusted or rebent? Also, one of the bearings on the plunger is squeeking. Does the plunger come out easily to replace it?
I can post some pix if necessary.
Thanks,
Warren
Thanks,
Warren
