V belt size for IHC simi mount sickle Mower.
Ah but which one as in what tractor does it fit. I have a mounted sickle bar mower on my BA that was made to fit an A so that is why I built the BA. I could maybe measure it and or find the number on it if it was the same model as you have
I think it was made for the H & M origionally. Maybe the C.
This one has a frame shaped like a V with a castor spoked rubber wheel at the point of the V.
Probably a 25 or 27 but there is a newer version that I do not know the number (31?) for and tractor model will not make a difference on that belt. Try Messicks and type in the 25 or 27 and see what comes up.
Should be easy enough to measure, no?
Just string some baler twine or whatever around the pulleys in place of the belt - and measure the length.
width will equal the pulley groove.
Mount it and then wrap 1/2 inch rope around the pulleys. Measure width for A or B belt.
Search web for best price for belt. I just needed a 131 inch A belt for my Cadet. Available at TSC for 63 dollars. Found on Amazon for 26.
I think that belt is around 7/8" wide and hard to find the wide ones and it would make no difference if mounted or not for measuring.
I found my operators manual/ parts list for my 25 V mower. It shows two belt part number / might get a belt at good auto parts store with the number. first number is M 32812 with a 10 7/8 drive pulley. and M 32813 with a 12 1/32 pulley. that is all I can help belt on mine is too bad to measure.
WHY just not get a belt from the FIAT dealer? Either of those numbers is still available and will cost between $25 and $30, and be CORRECT for the job!
