BANDITFARMER
Last while planting with the 8 20in AC planter I ran out of seed beans late one evening. I was looking for something in the barn and found 4 JD plastic soybean plates and figured I would try them in one side of the planter to see the difference it wound make. Next morning I installed the 4 JD plates in one side and left the 4 AC bean plates in the other side and filled with beans and started planting. Now the AC planter was set at 80 lbs to the acre. The next time I stopped to fill back up I found I had to add 1 more bag of seed to the 4 AC boxes to fill them full. When the beans came up you could see a difference in the beans that were planted with the JD plates, They were alittle bigger and looked better than the other 4 rows with the AC plates. So it put me to find 4 more of the JD plastic plates.
A seed dealer gave me 8 B3 32 cell soybean plates to use this year. He said with the small sized seed the seed companys are selling now I would be better off using these plates. When I asked how much of a difference it would make in the settings he could not give me any ideas. Said I would have to play with it to figure it out.
So the question is has anyone used these plates and did you have to change the seed rates up or down to plant the way you wanted it to? And how much of a difference is there between the B3 and regular JD soybean plates? I will post a picture of the 3 plate later today. Bandit
