Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD24T tight plunger shearing bolt
wilder11354
05-05-2013 20:01:18
Ohhh you mean doing something like this? strip out all guide plates, bead blast, grind down, beat with ballpeen rust built up between metal layers, pick out, new guides, adjuster plate, primed and painted, all new hardware. Then after plunger bearings and excessively worn plates are replaced it can be adjusted for guide clearances, and knife clearances? Also don't forget the pitman arm bushings and pin and shimming it to specs for for side play.
Copyright © 1997-2015 Yesterday's Tractor Co.
