Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: New Holland super 66 baler - twine question
Leroy
05-03-2013 09:01:13
And that is very likely a 6 volt starter as very few tractors used a 12 volt system then. They were just starting to come into general use.
jon f mn
05-03-2013 19:25:28
 Re: New Holland super 66 baler - twine question in reply to Leroy, 05-03-2013 09:01:13
Nothing wrong with turning the starter with 12 volt. I've been doing it for 15 years on my case dc with no problems.
Hogleg
05-04-2013 05:57:33
 Re: New Holland super 66 baler - twine question in reply to jon f mn, 05-03-2013 19:25:28
130/9000 poly would not work well in my 68 baler. Broken bales after tie. Went to 170/7200 and it works perfect. The first number is the tensile strength. The second is the length. 9000 is thinner twine. Did not hold on the bill hooks well in my case. Thicker poly fixed the issue. My opinion is that if 9000 sisal works then going to 7200 poly will work better than 9000 poly due to thickness. Just my 2 cents...
John
JRSutton
05-03-2013 11:54:04
You are correct. And as long as I'm around, there will always be at least one tractor with 6 volts nearby.
Even though it is intended to be used with 6 volts, it CAN be used with 12 volts too. I just wouldn't want to do it often. Not sure what could go wrong - maybe nothing. But I have no reason to find out.
Diydave
05-03-2013 15:20:06
 Re: New Holland super 66 baler - twine question in reply to JRSutton, 05-03-2013 11:54:04
Nothing will go wrong by jumping to a 12Volt system, just don't reverse polarity.
