Yesterday's Tractor Co.
Shop Now View Cart
Re: Little Genius keeps plugging up - need help
LA in WI
05-02-2013 09:09:12
I like using #9 wire better than any chain as wire has a smoother surface. I cut a 10 ft piece, tie one end to the coulter arm and let the rest of it flow past the moldboard. It is amazing how much better job of covering trash is done with using wires. After a lot of use you will often discover your wire has disappeared so you get to cut another one. (I never have found that first stays buried forever!).
LA in WI
05-02-2013 11:04:52
 Re: Little Genius keeps plugging up - need help in reply to LA in WI, 05-02-2013 09:09:12
Thank you. That is one of those tricks I've never had to use myself, but thought I had filed it away in my mind just in case I might need it someday.
There is also the trick of using plow jointers to get better coverage, but I don't think the jointers would help very much in heavy trash.
LA in WI
05-02-2013 15:36:35
 Re: Little Genius keeps plugging up - need help in reply to rustyfarmall, 05-02-2013 11:04:52
I have plow jointers for my #8 plow, and the best use for them is for "show & tell" at a farm show. They look nice but are pretty much worthless in the field, especially when trying to plow in cornstalks. I put them on for a farm machinery show and take them off when I plow!
LA in WI
05-03-2013 07:53:19
 Re: Little Genius keeps plugging up - need help in reply to LA in WI, 05-02-2013 15:36:35
I have just one jointer. It was on a junk, parts plow I bought at an auction. I probably should let my wife have it and let it be turned into some sort of "yard art".
