Yesterday's Tractor Co.
Shop Now View Cart
05-01-2013 19:01:18
I"m still confused. Pivot pin in bottom hole on feeder fingers with plunger face centered in front feeder slot on a compression stroke. Front finger is 11 inches from front of slot. From needle home position I tripped bale measuring arm and brought top of needles up flush with top edge of bale case bottom groove flange. Face of plunger to tip of needles measures 2 inches.
Do I still need to remove the cluster gear (timing gear) even though the clutch ring stop is against the roller at this point of the cycle? I realize an adjustment needs to be made, but am really confused with all the "book" dimensions checking out.
I even thought Deere may have sold me the wrong sprocket for the drive but it matched the old sprocket.
Tx Jim
05-02-2013 04:25:02
 Re: JD 336 BALER PLUNGER STOP in reply to JLU, 05-01-2013 19:01:18
OK so you're tripping bale length measuring mechanism then rotating flywheel moving PH on compression stroke when needle points rise to be even with the bale case upward protruding channels the needle points are 2"'s from PH face CORRECT????? Is needle brake snug enough to give resistance while trying to move needle frame by hand?? It this is correct then baler is in time with no need to remove gear.
05-03-2013 19:18:03
 Re: JD 336 BALER PLUNGER STOP in reply to Tx Jim, 05-02-2013 04:25:02
Mystery solved. The book doesn't tell you the baler has to be on a compression stroke when the needles become flush in bottom of bale channel. TxJim, you did mention this on one of your posts. I waited for the needles to make their move upward and when flush at bottom, measured distance to plunger face. Being new to the baler world and ironically on a decompression stroke, the needle to baler face measured 2 inches-exactly what the proper distance should be as described in book. This through me completely off. Thanks for your support Jim and Roger and the others who tried to help me out. This is a great site!
Tx Jim
05-04-2013 03:46:03
 Re: JD 336 BALER PLUNGER STOP in reply to JLU, 05-03-2013 19:18:03
I'm glad you got it in time. After you time a few balers you'll think "geez this is easy". :wink:
05-02-2013 05:26:27
Yep needles are 2 inches from plunger face. I can't seem to raise the needles at all by hand. Brake too tight? Could this baler be 180 degrees out of time? I said in first post the plunger stop wouldn't retract until 3/4 of the way through a compression stroke, but looking closer last night the plunger is actually just starting to retract back in bale chamber when the plunger stop releases.
