Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Corn binder elevator question
Leroy
04-30-2013 10:59:28
Ground drive shreader is something else as a corn shreader is a flat belt drive from the belt pully on that H. You set it up same as a threshing machine for wheat-oats. Never raised beef cattle only milkers. And it would just plug the feed rolls if you tried to put hay in it. There are 2 rolls that are snapping rolls and mine being a smaller size has 4 husking rolls while the larger model has 6 husking rolls.
Farmallb
04-30-2013 15:31:12
 Re: Corn binder elevator question in reply to Leroy, 04-30-2013 10:59:28
I guess I got you confused somewhere Leroy. I have BOTH a NI Shredder, AND a Ground Drive IHC Binder. Mine likely is a smaller size. It looks to be 2ft wide. SHREDDER, that is
Leroy
04-30-2013 17:42:54
 Re: Corn binder elevator question in reply to Farmallb, 04-30-2013 15:31:12
Your line is "my shredder is ground drive", I think you were thinking binder and typed shredder, easy done and I read my posts about 3 times because of that problem. The New Idea shreader was built about 40 mile from me amd one neighbor worked in the factory years ago and some friends worked in the engineering department when they closed the factory that the town wants to make into a musuem but the EPA is balking because there is paint in there from when it was used as a factory.
